| Message |
Check your Clutch Fluid. if its black you might want to change it. Or if its low top it off.Start there ... I used a fluid pump to drain the fluid from the reservoir, added new fluid,(closed the cap), pumped my clutch like 40 times, REPEAT this step like 10 times or until your fluid comes out clear again. it worked for me and even gave me a better clutch feel.
